May 14, 2013 10:59 PM UTC
Customization.ui
Creo Community,
I just installed build M050, and normally I copy my customization ui
file (creo_parametric_admin_customization.ui) to :
C:\Program Files\PTC\Creo 2.0\Common Files\<build>\text
This is not working. Any ideas?
Brad
    May 15, 2013 10:15 AM UTC
    I've found with an externally loaded file it doesn't recognise it first time, you have to Import it from the menu customisation window then it fixes, make sure you apply all customisation or it will only apply to the current interface.
    I ended up making a little list of all the environments I work in as the customisation is seperate for each one, this is good once your up and running as each interface has different prioritites but is a bit time consuming initially, even part mode in the asm (RMB > Activate) has its own interaface,
    May 15, 2013 12:09 PM UTC
    Don't forget to add in the config line:
    load_ui_customization_run_dir YES
    Without this it won't read the file.
    In Reply to Brad Mozley:
    Creo Community,
    Brad
    May 15, 2013 12:17 PM UTC
    This is not necessary. It also looks like a big time sink.
    Try this:
    1. Create the customization you'd like to use. You'll have to do this separately with each mode. (You said you have many different customization files already created. I'm not sure if you can simply load these sequentially or if you'll have to recreate a single customization.ui that incorporates each mode.)
    2. Once each mode is customized the way you'd like, export the .ui file. Place it in your Start In directory. (Alternatively, if it's going to be used company-wide, rename it to creo_parametric_admin_customization.ui and put it in the load directory's \text folder.)
    3. Add a config line: 'load_ui_customization_run_dir YES'
    Now when you launch, it will pick up the new ui. No need to load up a bunch of customization.ui file every time you launch.
    In Reply to Sean Kerslake:
    May 15, 2013 12:25 PM UTC
    Hello all,
    Does anyone have a 3D model of Intel NUC D33217GKE board that they can share?
    Jay
    May 15, 2013 12:26 PM UTC
    This the info I have put in our config.pro together with the config option.
    It tells the whole story:
    ! Creo Configuration files are read from these locations (in this order):
    ! 1. %ptcwfroot%\.Settings
    ! Note: This is equivalent to %AppData%\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings
    ! o Only .ui with the name: creo_parametric_customization.ui
    ! Note: UI changes will be stored here unless you set the option mentioned under #4
    ! These changes are supplementary on any admin file mentioned in #2
    ! o No other config files.
    ! 2. <creo load=" point=">\Common Files\<date code=">\text
    ! o Only .ui with the name: creo_parametric_admin_customization.ui
    ! Note: admin .ui files cannot be directly edited. Before editing, copy it to #1 or #4 as a normal .ui
    ! o config.pro, config.sup, menu_def.pro, protk.dat
    ! 3. %HOME% (c:\users\%username%)
    ! o Only config.pro, menu_def.pro, protk.dat (no .ui or .sup)
    ! 4. Start in directory
    ! o Only .ui with the name: creo_parametric_customization.ui AND when config load_ui_customization_run_dir is yes
    ! Note: System Info will only display filename: not entire path
    ! o Only config.pro, menu_def.pro, protk.dat (no .sup)
    ! Enable reading creo_parametric_customization.ui from startup dir
    ! See:
    To: -
    Date: 15-05-2013 01:00
    Subject: [proecad] - Customization.ui
    Creo Community,
    I just installed build M050, and normally I copy my customization ui file (creo_parametric_admin_customization.ui)to :
    Brad
    Site Links: View post online View mailing list online Send new post via email Unsubscribe from this mailing list Manage your subscription
    Use of this email content is governed by the terms of service at:
    May 15, 2013 1:15 PM UTC
    I did the same for both M030, M040 and now M050 without any problems at all.
    I have not installed my Creo in C:\Program Files, but in C:\Programs to work arounds Windows 7 administrator rules for easy update from a network drive upon application launch.
    /Bjarne
    May 15, 2013 1:22 PM UTC
    I believe that it should read the creo_parametric_admin_customization.ui file from the text folder regardless of that config setting.
    There is a problem with that setting, but it may not matter to you depending on how you work. This tells Creo not only to load the creo_parametric_customization.ui from the working directory, but to save it there as well. The problem comes when you change your working directory during the day.
    You launch Creo with folder A set as the start in folder. The creo_parametric_customization.ui file found there loads at startup. You then change your working directory to folder B, your project folder, and begin your work. Along the way you add an icon to the quick access toolbar, prompting an automatic save of the creo_parametric_customization.ui file into folder B. Tomorrow, when you launch Creo, your new icon is not in the quick access toolbar because your creo_parametric_customization.ui file was not saved to the startup folder, folder A. Not to mention that you end up with creo_parametric_customization.ui files in all your project folders and if users share folders they overwrite each other's creo_parametric_customization.ui files.
    May 15, 2013 1:25 PM UTC
    Is this always the case with newly copied files? I plan on creating a creo_parametric_admin_customization.ui file and copying it via my launch batch file into the text folder. Are you saying that it will have to be manually loaded each time? That's going to be a problem.
    May 15, 2013 1:47 PM UTC
    Since he had already mentioned he gave it the correct admin name, I didn't bother to point this out.
    Since we WindchillPDMLink instead of working folders, this is something I had not encountered. Sounds like it's working similar to many other functions Pro/E has always done with regards to working folders. Not the most well thought out situation from PTC.
    In Reply to Doug Schaefer:
    May 15, 2013 1:50 PM UTC
    No. It's my understanding that if you copy the admin .ui file into the correct folder - usually /text - AND you have the config.pro option set correctly, it will load it without issues. It's been around 6 months since I was testing this, but unless my memory is failing me it worked just fine once the config option was in place. No need to load it every time.
