default_dim_num_digits_changes in WF5?
- 6 replies
- 3404 views
- Translate All
Any idea what's default_dim_num_digits_changes used for? In WF5, it causes negative dimensions to be rounded during 'edit definition'. See short video attached. Rather dangereous, since the actual distance between the two planes is rounded, in the video from -5.5 to -6!!
Regards, Hugo.
