Sep 29, 2015 8:46 PM UTC
Friction but no ground springs please
I may have asked something similar before, possibly associated with large deformation analysis.
Friction requires large deformation analysis.
Am I right that we can't have a ground spring if we do the above?
    2-Explorer
    Oct 9, 2015 5:25 PM UTC
    I guess calculation of friction (contact) is nonlinear.
    Nonlinear analysis is not supported with non-simple spring - this has been confirmed for Creo Parametric 2.0
    (by mistake the article CS94508 was not visible - I changed this now)
    346gnu13-AquamarineAuthor
    Oct 10, 2015 3:55 PM UTC
    Thank you Gunter,
    A work around used in these events is to have a simple point to point spring. Keep the points close together. Constrain one end of the spring with a normal displacement constraint effectively making it a ground spring.
    If stiffness is required in more than one direction, create mutually perpendicular springs to a common point, each spring's second point has its own displacement constraint (ground).
