Gear tooth deflection - shrink fit
I need to run an analysis on a gear to see the tooth deflection induced by the shrink fit of the bore on to a shaft. Loading is easy just a simple pressure load applied on the bore, but how do I constrain it properly? I was thinking perhaps using a cyclic constraint? Any ideas?
Chris.
    Chris,
    Cyclic symmetry on a "pie slice" model in case of a strictly radial load/deformation (as in your case) is equivalent to the"reflective/mirror symmetry", so I'm not sure why it's not working for you, perhaps there's something else that's missing in your model. (Note that "reflective symmetry" couldn't replace "cyclic symmetry" if a tangential load was applied, as Jim Holst correctly points out.)
    However, that's not really important. If 1/4 model withmirror symmetry works for you, that's perfectly fine.
    The rest -- just minimally constrain the model in axial direction, as Stephen Seymour recommends, no need to use springs or overconstrain by applying on both sides.
    Yuri
