Oct 18, 2016 6:53 PM UTC
How can we create the following texture types in Creo.
    StephenW
    Oct 18, 2016 6:56 PM UTC
    See this post. It has a good video tutorial.
    Working with Images and Decals in Creo Parametric
    rabraham1-VisitorAuthor
    Oct 18, 2016 8:36 PM UTC
    I am trying to create these textures as a parametric model. Not to place as an image or as a decal.
    Oct 19, 2016 12:44 AM UTC
    Input begets output.
    With great effort you can create this very geometry.
    2-Explorer
    Oct 19, 2016 5:35 AM UTC
    Hello rabraham
    it´s a great and complicated question. Can give you some basic tips, but this problem needs big research from your side.
    Principaly you need 2 similar textures. See Creo default texture directory, there you will find some samples.
    Without Advaced rendering extension (ARX - Photolux) you are not able to rech desired result. Basic Render is not able to do something like this texture.
    1. Color texture                                          2. Bump texture
    Using 2 textures in Model appearance editor:
    Use exact same setting for both textures:
    Also see following topic in order to keep your textures "smooth"
    How to make: "Smooth multiple textures"
    Hope this basic information can give you direction which to go...
    Regards
    Milan Bonka
    Oct 19, 2016 4:36 PM UTC
    I am not looking from a rendering perspective.
    Need to create as a parametric cad model.
    Dale_Rosema
    Oct 19, 2016 8:33 PM UTC
    Check out this discussion:
    Re: Creating a wool-like fabric in creo 2.0
