Jan 31, 2014 11:17 AM UTC
PDMS VS CREO
Dear Folks
Did any one aware of PDMS?
is't possible to work in creo = PDMS?
thanks in advance
Regards
Viswanathan.K
    Jan 31, 2014 7:20 PM UTC
    These are two different functions. Typically, the PDMS is a place that manages the files created by Creo.
    visu1-VisitorAuthor
    Feb 1, 2014 2:25 AM UTC
    But my question is?
    the way pdms was multi user working enviorment.
    is't possible same? in creo?
    2-Explorer
    Feb 1, 2014 8:32 PM UTC
    Ask a much longer question.
    Ask someone with better English to help translate.
    I think you have a good question but the translation is not good.
    StephenW
    Feb 1, 2014 2:45 PM UTC
    PDMS is a usually associated to plant design, especially piping design. Plant Design Management Software and is extensively in chemical and energy plants.
    PDM is an abbreviation for Product Data Management. Creo uses PDMLink and formerly used Intralink and Pro/PDM. UGNX uses Teamcenter. Solidworks uses Enterprise PDM. You can mix and match PDM systems with design softwares but it usually requires some sort of 3rd party integration.
    Not sure which one you are refering to.
