Sep 24, 2014 3:15 AM UTC
Quilt edge display in creo2
How to switch on quilt edge display in shaded view status?
I used to do that in WF4, the open quilt edges were highlighted in yellow color....(it was in View-> model display tab) but the similar option if available in creo, pls discuss how...?
that will be use ful while fixing complex quilt open edges
    Sep 24, 2014 4:45 AM UTC
    Mahesh,
    one-sided edged have Letter color assigned in Hidden line mode. By default it is blue in Creo Parametric 2.0. You can change it using File > Options > System Colors > Graphics > Letter.
    Then you can Export color scheme into .scl file and set config.pro option
    system_colors_file PATH_TO_syscol.scl_file
    Martin Hanak
    mms-21-VisitorAuthor
    Sep 24, 2014 4:50 AM UTC
    Hi Martin,
    my issue is exactly the below link http://communities.ptc.com/thread/42702?tstart=0
    can you help... quilt edge visibility in shaded mode....
    Sep 24, 2014 5:19 AM UTC
    Mahesh,
    I think you have two options:
    1. ask PTC support
    2. use some workaround, eg. select surface edges and create Copy feature (curve) using CTRL+C and CTRL+V shortcut
    Martin Hanak
    Mahesh_Sharma
    22-Sapphire I
    Sep 24, 2014 8:42 PM UTC
    Mahesh,
    This is because of change in functionality from Creo 1.0. However you can use search tool to find one-Sided edges in part. Sreach > Lookin for Edge > Attribute as Type > value as One - Sided.
    Sep 25, 2014 2:55 AM UTC
    Hi Mahesh Sharma,
    Good moring..
    I tried and it shows all the one sided edges n the part,... meaning open edges in construction surfaces as well....
    imagine a big part with lot features
    even i was not using it till date...
    thanks for the command
