Mar 15, 2011 8:45 PM UTC
Summary - def_layer
Huh, sounds like it's not possible.  Goofy.  I'll just create rule
driven layers with the same names.
Doug Schaefer
    Mar 16, 2011 9:53 AM UTC
    Perhaps you could try this :
    - create a new assembly (with layers defined by def_layer).
    - put in this assembly all you want to update
    - then in this assembly, choose to propergate layers to all members (with extend rules).
    Is it something like you wanted to do ?
    GB
      ----- Message d'origine -----
      De : Doug Schaefer
      À : -
      Envoyé : mardi 15 mars 2011 21:45
      Objet : [proecad] - Summary - def_layer
      Huh, sounds like it's not possible.  Goofy.  I'll just create rule driven layers with the same names.
      Doug Schaefer
    Mar 16, 2011 12:22 PM UTC
    Two problems with that approach:
    1 - A new, blank assembly will have no layers in it.  The layers defined by config.pro 'def_layer' statements are only created when needed.  So, until you create a plane, there is no plane layer.  I'd need an assy with a plane, an axis, a cosmetic, a GTOL, a curve, a surface and a coordinate system. 😄
    2 - Even if I did that, I'm not sure that these kind of layers would respond to the 'extend rules' command since they are not based on rules.
    Also, I did forget to mention that two folks said that Model Check could do this, but I don't run model check here and don't really want to figure it out for this.
    Doug Schaefer
