The Old Farts Guide to the PTC Community - Setting Up Streams, Following Communities, & Filterin
  • March 31, 2015
  • 27 replies
  • 23140 views
After you have an account set up, Pick on the PTC Community title to go to the Welcome page.
    David,
    Nice job. Except your images are not showing. All I get is junk like this: [cid:image001.png@01D06BBE.33072950]
    Is this something I can fix on my end?
    Herb Spaulding
    StephenW
    Because the attachments (pictures) make the email too large (by ptc user standards), you will need to look at the post online.
    Stephen Williams | Mechanical Designer
    StephenW
    And there they show up as attachments.
    2-Explorer
    April 1, 2015
    Formatted it as a Word doc. See attachment.
    davehaigh13-AquamarineAuthor
    It was brought to my attention that all the pictures got stripped out and you have to go to the PTCUser to download them. Attached is a pdf. I'm sure it will get stripped out also, but at least you can go download the pdf.
    David Haigh
    .pdf is the best format for portability; some of us don't us MS office...
    Christopher F. Gosnell
    FPD Company
    124 Hidden Valley Road
    McMurray, PA 15317
    I just realized I made a mistake.
    I said, "From the welcome page you want to set up some "Streams" The names you give these will show up in the emails you receive."
    Turns out that's not true. Those names are not set by what you name the stream. They are hard coded by the web site.
    I realized this after I stated following the modeling community. I started getting emails in my in-box with this in the subject line:
    Thank you!
    This old fart needs all the help he can get!!!!!
    I second that!
    If the PTC/Community admins have tips and tricks, or tutorials….. This old fart would appreciate the assistance
    StephenW
    There are a couple of documents in the community help area about following streams.
    | LinkedIn<">http://www.linkedin.com/company/national-oilwell-varco?trk=tyah&trkInfo=tarId%3A1405455811306%2Ctas%3Anational+oilwell%2Cidx%3A2-1-4> | Twitter<">https://twitter.com/NOVGlobal>
    The information contained in this transmission is for the personal and confidential use of the individual or entity to which it is addressed. If the reader is not the intended recipient, you are hereby notified that any review, dissemination, or copying of this communication is strictly prohibited. If you have received this transmission in error, please notify the sender immediately.
