Jun 26, 2014 1:59 AM UTC
use one sketch for multiple features...
... is it possible?
    Jun 26, 2014 2:23 AM UTC
    ...yes
    Jun 26, 2014 6:45 AM UTC
    Eugene,
    create Sketch feature (datum curve sketched in datum plane) and use it as reference in the following features.
    Martin Hanak
    Jun 26, 2014 9:06 AM UTC
    Martin, I do know about external sketch of course
    I shoud ask if an internal sketch used in a feature can be reused in another one.
    Jun 26, 2014 9:13 AM UTC
    Eugene,
    the answer is NO. Internal section/sketch is hidden inside its feature and cannot be referenced from outside.
    Martin Hanak
    Patriot_1776
    Jun 26, 2014 1:29 PM UTC
    It absolutely can be. Unlike older versions of SolidQuirks, you can sketch a stand alone datum curve, and use elements of that for any number of features (in the internal sketch) or even parts if done correctly.
    I believe David is right as well.
    Jun 27, 2014 8:37 PM UTC
    The correct answer is:
    make a "copy" of your sketch in a feature and than you can bring it into a sketch that you want to create
    So david and Anton both got it right.
    thanks
    Jun 27, 2014 11:11 PM UTC
    Interesting. It works the same as the sketch palette without having to save the section. This will be useful.
    The same limitations exist as well since you loose your references.
    I for one would really like the option to change internal sections to external sketches after the fact.
    Jun 28, 2014 12:06 AM UTC
    There is this use in session tool in sketcher,but sketches are named in a way that you won't be able to distinguish them and if you ask for preview it crashes the whole application.
    Jun 28, 2014 12:43 AM UTC
    you can use the thumbnail preview for this.
    Jun 30, 2014 12:48 PM UTC
    I seldom use external sketches because back in release 14 when I learned, they didn't exist. I reuse internal sketches often. Like Stephen said, if you save the sketch it becomes a .sec file, which you can import when starting a new sketch. The .sec file then becomes the internal sketch for the new feature.
