Tool Design & Mold Analysis Tips & Techniques Session recording (East Coast)
  • April 9, 2026 at 8:36 PM
  • 8 replies
  • 2725 views
  • Translate All
Check out this video on Tool Design & Mold Analysis  from PTC Application Engineers
Presenters: Lee Goodwin (Technical Specialist), Lino Tozzi (Technical Specialist, Fellow) and Tom Quaglia (Creo Segment Sales )
Original Date Presented: September 16th 2021.
Webcast Q&A
Question from Al:  How do you model/work with a mold that has a multiple core pins that creates cavities in the part?
Answer:  You would create multiple volumes and extract them from the overall volume.
Webcast Q&A
Question from Anonymous:  When are the menus going to be updated?
Answer:  Good question!  We left a few old school menus for nostalgic purposes 😉
8-Gravel
October 26, 2021
Being new(ish) to Creo we struggle with this as its so out dated compared to the rest of the software
Webcast Q&A
Question from Chris:  There are complex parts that need 3 mold parts.  Can you show us an example?
Answer:  There can be hundreds of parts to the mold if desired.  You do this by creating multiple mold volumes/parting surfaces.
Webcast Q&A
Question from Claudiu:  Is Creo able to have analyze feature find a minimum distance between a Runner Mold Feature and a Cut or Hole?  I've seen that there is an analyze feature (close proximity) between a Water Line and a hole, but I would like to be sure the hole is not closed to a runner.
Answer:  You could do a minimum 3D thickness check.  Aside from that, you have full measurement/clearance checking.
Webcast Q&A
Question from Kunal:  How can we create undercuts?
Answer:  Same as any other parting surface but the undercut will show up as a potential issue.  You can leave it as is if you wish.
Webcast Q&A
Question from Michael:  Is Creo able to determine the flow of your water lines and advise what your Reynolds number would be?
Answer:  Yes, with Creo Flow Analysis.
Webcast Q&A
Question from Paul:  With glass polyester, there is part shrinkage.  How do you accommodate that?
Answer:  Shrinkage can be added isotropic or anisotropic.
