Jun 30, 2026 5:01 AM UTC
Accessing 'Cleanup Dimensions' for an Entire Drawing Sheet via Creo 10 J-Link API
1."Can we perform a 'Cleanup Dimensions' operation across all views of a 2D drawing sheet simultaneously by passing a NULL view pointer in the J-Link API for Creo 10?"
2."In Creo customization using J-Link, is it possible to cast a standard pfcDrawing object to a wfcWDrawing object to access Web Foundation Class methods?"
Emeritus
Jul 10, 2026 4:30 AM UTC
Hi ​@Shanmugaraj Nagaraj ,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
