Adding "Square" (²) Symbol in creo parametric 2.0 drawing notes
  • June 4, 2018
  • 5602 views
Hi All,
I'm facing an issue while creating drawing notes in creo parametric 2.0  from model server as explained below.
When I enter the note in drawing having character x², model server is some how converting the square symbol to x² .
Did anyone one face same issue & got the solution ?
I appreciate your time 🙂
Could be font related.
Are you using the superscript on/off option in your text string for the '2'?
MS_161-VisitorAuthor
Hi Ben,
Could you please explain me lil bit about, how do I use superscript on/off option ?
Thanks of your reply.
