Aug 11, 2022 10:22 AM UTC
Bolted connection
Is it possible to make a bolted connection of bolt, washers and nuts (not a sub assy) like in inventor. Then easily place it in mutiple locations with minimal constraint requirements to position.
Chris3
Aug 11, 2022 10:48 AM UTC
Yes. Make a group of the components you want and then do a copy paste special with advanced reference configuration. Then it will only prompt you to pick the new references. I have a mapkey that does the paste part so all I need to do is pick the new references.
Aug 11, 2022 10:50 AM UTC
And this will only ask you to constrain the surface and  hole?
joe_morton
Sep 15, 2022 3:57 PM UTC
I think this would be dependent on the mates from the first set of components.
So if you had constrained your bolt, washer, nut with 3 references, the paste would ask you to select 3 new references.
Aug 11, 2022 11:29 AM UTC
Can't you do that using AFX?
Like in
https://www.youtube.com/watch?v=DfapTZHq2pM
FV_01
Aug 15, 2022 9:31 PM UTC
Somewhat similar to Inventor functionality. A part with a multi-body 'fake' - one body is a bolt, another is a nut, etc... Nut-body would have an offset datum plane as its sketch plane.  The offset dimension to be a future stack thickness.
In assembly context. Flexible component dimension is the offset plane dimension; therefore, assembly stack thickness is unique to a specific component and does not affect the original part dimension(s)
Component interface is defined as a placing type, a coaxial axis and a mating datum plane.
HIH.
