3-Newcomer
Creo 9.0 and Simscapre
Does anyone know if it is possible to get Matlab Simscape to work with Creo 9.0?
I am using the student version since I need this for a project.
I manage to get it to link but I seem to be having trouble getting it to work.
For some reason, I get an error when trying to generate a XML file.
Any help will be appreciated,
VladimirNAnswer
Found another resolution here:
https://ch.mathworks.com/help/matlab/matlab_env/contact-technical-support.html
https://ch.mathworks.com/support/contact_us.html
3-Newcomer
I already went through all of this information to get the plug-in to install to creo so I see the TOOLKIT tab.
I get it to the point where I try to generate an XML file but then the XML file will not generate,
Im using Matlab R2021A and Creo 9,0 would I need to update my Matlab to R2023? Would that help?
VladimirN24-Ruby IVAnswer
