9-Granite
Dec 5, 2025 6:40 AM UTC
Creo: Map ordinate dimensions to zero plane without Toolkit license
Creo (non‑licensed Toolkit APIs):
How to map ordinate dimensions to their zero plane in a drawing view?
I need to identify, for each ordinate dimension in a Creo drawing view, which zero/baseline plane it references. I know ProDimensionAttachmentsGet() in Pro/Toolkit(licensed API) can do this, but I don’t have a Toolkit license.
Is there a way to achieve the same using non‑licensed APIs (e.g., VB API/.NET or OTK Java), or a reliable workaround to traverse attachments/baseline direction for ordinate dimensions?
Emeritus
Dec 12, 2025 6:48 AM UTC
Hello @AS_13847166,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
