9-Granite
December 5, 2025
Creo: Map ordinate dimensions to zero plane without Toolkit license
  • December 5, 2025
  • 258 views
Creo (non‑licensed Toolkit APIs):
How to map ordinate dimensions to their zero plane in a drawing view?
I need to identify, for each ordinate dimension in a Creo drawing view, which zero/baseline plane it references. I know ProDimensionAttachmentsGet() in Pro/Toolkit(licensed API) can do this, but I don’t have a Toolkit license.
Is there a way to achieve the same using non‑licensed APIs (e.g., VB API/.NET or OTK Java), or a reliable workaround to traverse attachments/baseline direction for ordinate dimensions?
Community Moderator
December 12, 2025
Hello @AS_13847166,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
