18-Opal
Aug 6, 2026 2:44 PM UTC
CREOSON AI MCP Interface (tested - what is next?)
A preview of something that is being tested within CREOSON, looking for feedback and ideas.
Keep these questions in mind as you read:
  • Do I (or my company) care about my data going to someone else’s AI / Cloud?
  • What use cases, processes, interfaces cause pain today?
  • How could this change my day?
  • Why do I care?
The intent is to provide a FREE AI MCP (Model Context Protocol) interface within CREOSON that enables your AI Agents to connect to and drive Creo Parametric either as a specific set of contextual tasks - or within the context of other systems/environment workflows (e.g. YOUR models, standards, documents, EPR, PLM, etc.).  Seems like this would be super powerful, and provide a lot of utility.
This screen capture is an example of an AI Agent validating a connection to a new CREOSON MCP Endpoint (prototype currently).
CREOSON - AI MCP Endpoint First Connection Test Result
The CREOSON MCP Server enables you to choose/bring your own AI (Commercial Platform or Local AI).  The screenshot above was tested using an Anthropic’s Claude Code (linux desktop) talking to a CREOSON / Creo Parametric Session across the network on a Windows 11 Machine. 😎
Talking to Big-Iron AI (Claude-Code, Codex, Gemini, Grok, etc) is for sure useful, but every interaction is training those models with your data.
I think that Local AI will be a top priority very soon for companies - especially regarding designs, specifications, internal documentation that represents genuine Intellectual Property that should not go to Cloud AI Models.
Local AI is coming (technically - it is already available/here)… and enables
  • No AI platform dependency (multiple/capable open source models available)
  • No extra licensing fees required (you pay for power, not tokens),
  • Sovereign - YOUR data, processes, and interactions remain YOURS and in YOUR control (perfect for air-gapped or highly-regulated environments),
  • Flexible/Trainable/Extendable - easily connect to your documents, systems, and build your own skills (secret sauce) for what and how you do what you do...
Bonus regarding Local AI - most CAD systems already have very capable graphics card for running CAD and AI locally (low barrier to implementation/access).
Properly done, this would enable your Creo Models / Drawings to be folded into the context of other processes and workflows (documents, standards, specs, other MCP services in/out of your organization).
Any feedback on this potential CREOSON MCP capability?  Suggestions? Thoughts?
Dave
18-Opal
Nov 10, 2026 1:49 PM UTC
Ok, this was NOT on the bingo card for today - cool and scary at the same time.
I was running a quick Creo Parametric drawing creation/automation test with CREOSON MCP (beta) connected to a Cloud Language Model. I deliberately created a Creo Drawing Template so that some views would likely bled the drawing sheet boundary when the dimensions were shown. The point was to see if/how SI/AI would overcome Creo API limitations to support my objectives given a poor starting point.
During the execution, the AI did something I DID NOT EXPECT. Specifically, ON ITS OWN... without ANY instruction from me, it generated a PDF of the created drawing state and passed that to the Language Model for visual review/context; then the AI planned the fixes using the known API calls to finalize the drawing view placements. 😳
Did it work?! YES - super impressive, slick, kind of a pinch yourself moment. The result was 95% there - some dimension clean up always required; and the AI even reported dimensions that were not visible in the available views. Seems like a huge win.
However, the AI generated and sent off that PDF to the cloud WITHOUT asking permission - it just "did it" - IT decided the path and executed. And... THAT should create massive pause to anyone considering connecting Cloud AI Models or Services to their CAD - or any other company data for that matter.
#LocalAI is the future. 🤠
