3-Newcomer
May 5, 2026 3:00 AM UTC
.dtl Setting for the Length of Section View Reference Lines
I want the reference line for a section view to extend out of an orthogonal view less than it does here, by default. Is there a .dtl setting for that?
Emeritus
May 12, 2026 4:39 AM UTC
Hello EP_14482788,
Thank you for your question.
Your post {.dtl Setting for the Length of Section View Reference Lines | Community} has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
KenFarley
May 12, 2026 11:10 AM UTC
I don’t think there is a setting that specifically addresses your desires. I’ve just lived with this behavior for decades.
You could try scouring the drawing setup options. Here’s a good place to find them:
https://creosite.com/index.php/configuration/drawing-setup-option-search/complete-lists-of-drawing-setup-options/
I did a bit of a look, but didn’t see anything obvious. Look through them yourself for your particular version of Creo, maybe you’ll get lucky. It might be a case of some other setting affecting this one, too. Or, there might just not be a user-changeable setting. It wouldn’t be the first time.
MikeBennett
May 12, 2026 11:52 AM UTC
HI ​@EP_14482788
There are a couple of knowledgebase articles that ask a similar question about the length of the section cutting line, distance between the view and arrow, and length of the arrows, both of which recommend to create a Product Idea to request the addition of such a feature.
CS247485 & CS76342
