3-Newcomer
Oct 10, 2026 1:31 PM UTC
Getting data from MSSQL to Jlink problem in Creo 12.4.3.0 and sqlite-jdbc-3.50.2.0.jar.
I have the same problem as mentionde in topic In Creo 12.4.3.0 and sqlite-jdbc-3.50.2.0.jar.
The code below shows no driver was loaded.
log.debug("List JDBC drivers:");
ServiceLoader<Driver> loadedDrivers = ServiceLoader.load(Driver.class);
for (Driver driver : loadedDrivers) {
log.debug(driver);
Even with this code, no driver found.
Class.forName("org.sqlite.JDBC");
This line in parametric.psf show also no effect.
ENV=PRO_JAVA_COMMAND=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\jdk21.0.10_7\bin\java.exe -Djdbc.drivers=org.sqlite.JDBC
Any ideas?
    Emeritus
    Oct 16, 2026 5:20 AM UTC
    Hi ​@ptc-3260011,
    Thank you for your question.
    Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
    Vivek N
    Community Moderation Team
