May 25, 2016 1:33 PM UTC
Getting ProUISpinbox value in CREO Toolkit
     I am repeatedly getting fatal error when try to get the value of spinbox, My code is below
int RunSpinBox()
  ProError status;
  int   i;
  char * dialog = "mcheck_plus_resource";
  ProUISpinboxIntegerGet(dialog,"ItemValue",&i);
  MessageBox(0,i,"SpinBox Value",1);
I have attached error file. Please anybody help to solve the issue.
May 26, 2016 12:44 PM UTC
I'd say that the error is caused by the MessageBox function.
Here is the function prototype as described on MSDN website:
int WINAPI MessageBox(
  _In_opt_ HWND    hWnd,
  _In_opt_ LPCTSTR lpText,
  _In_opt_ LPCTSTR lpCaption,
  _In_     UINT    uType
First function parameter is of type HWND and you are using an constant integer (0). Second parameter has to be a string and you are passing an integer.
Normally this types of errors are captured at the compilation time.
Personally I prefer to use ProUIMessageDialogDisplay instead of MessageBox.
Other items you need to double check are the dialog and spinbox names? Do the "mcheck_plus_resource" and "ItemValue" match the names on your resource file?
  _In_opt_ HWND    hWnd,
  _In_     UINT    uType
