6-Contributor
Mar 28, 2024 3:05 AM UTC
How to create square image from Creo Rendering
I want to generate a square Image of 1000x1000 pixel from Creo Rendering.
Currently the images generated are in Rectangular format (500x1000).
Also is there a way to change drawing window size width through config file ?
 Thanks in Advance…..
ps56-ContributorAuthor
6-Contributor
Apr 2, 2024 6:24 AM UTC
I need it in 1000 X 1000 resolution
Apr 2, 2024 10:51 AM UTC
if you are PTC Customer with active support then contact PTC Support directly and ask them the same question.
Apr 5, 2024 7:56 AM UTC
https://www.ptc.com/en/support/article/CS414760
  • Add hidden config.pro option force_base_size to 700 700 and restart Creo Parametric.
    • In Render window set the Resolution to 1000 1000 or 500 500.
Community Moderator
Apr 5, 2024 8:35 AM UTC
Hello @ps5,
It looks like you have some responses for your topic. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
