Jun 17, 2015 3:41 PM UTC
How to make a hole pattern a datum reference for GD&T?
I want to make my hole pattern datum C and reference it in a feature control frame. How do I do that in Creo?
Jun 17, 2015 5:25 PM UTC
David,
In all due respect, it is the axis of the pattern, not an axis of one hole of the pattern, as I understand y14.5 1994
Ron
lwestlake1-VisitorAuthor
Jun 17, 2015 5:06 PM UTC
I should say, how do I attach a datum tag to a hole pattern...
2-Explorer
Jun 17, 2015 5:22 PM UTC
A datum reference symbol is typically attached to the diameter dimension of the holes in a pattern. Create an axis through one of the holes (never use an axis that's part of a feature unless you want to make things more difficult) and then choose "IN DIMENSION" or whatever is right for the version of PTC software you are using.
David,
Ron
Jun 17, 2015 7:28 PM UTC
When you use a hole pattern as a datum it establishes 2 mutually perpendicular planes at the center of the pattern ...and since I'm locating the pattern to a datum plane that keeps it from rotating.  I just wanted to know how to create the datum tag in Creo and I figured it out by trying the suggestions given here.  Thank you!  I'll probably be visiting this forum more often!
Thanks for all the quick responses.
Lori
Dale_Rosema
Jun 18, 2015 5:40 PM UTC
Don't forget to mark an answer as correct, even if it is your own, so that those following behind will know that an answer has been found.
Jun 18, 2015 6:03 PM UTC
My pattern happened to have been 2 holes so I created a datum plane thru each holes' axis and named it "C".  Then as David said I chose "IN DIMENSION" and attached it to the 2X dia. dimension of the hole I am calling out on the drawing.  Because the datum tag is attached to a 2X dimension - this indicates the pattern is the datum.
Cheers!
