Jonathan_Felipe
Improvement Suggestion – Appearance Organization in Creo Parametric
Dear Team,
We operate in an environment where several industries use Creo Parametric for the creation and editing of appearances applied to parts and wires. We are currently using Creo Parametric version 12.0.2.0.
We would like to suggest an improvement related to the organization of custom appearances. Currently, all created appearances are grouped under the “My Appearance” tab, which mixes appearances intended for wires, solid models, and sheet metal. This limitation directly affects organization and workflow efficiency.
Our suggestion is to allow the creation of new custom tabs or categories within the Appearance Manager, enabling users to separate appearances by application type (wires, solids, sheet metal, among others).
This functionality would significantly improve ease of use when creating and editing appearances, as well as provide better color organization. As a direct result, it would also help reduce design time, leading to increased productivity and cost savings for companies.
Thank you for your attention. We remain available for any additional details or practical examples of this request.
Jonathan_Felipe
VladimirN Thanks for the comment, I've already done that.
