3-Newcomer
Sep 1, 2026 8:03 AM UTC
Line Thickness in 2D not showing up in exported SVG file.
Hi everyone, i have tried all settings in Creo illustrator standard (12.1) and have changed my line thickness for 2D and it still no luck in seeing two different line thickness when opened in Adobe illustrator.
Below is what i have done.
  1. Render mode set to HLR
  2. Change pen settings - In File/Options/illustration/Pens/Thick/edit - changed 0.35 - Apply
  3. Change pen settings - In File/Options/illustration/Pens/Thin/edit - changed 0.25 - Apply
  4. Export to svg - File/Save Figure as/Save as illustration file/File name - Tick Thick/Thin lines - Tick Polylines - Tick Fixed Size - Include hotspots for callouts - Tick Combine hot spots for same item. then click “OK”
  5. Open file in Adobe illustrator and all lines are the same thickness, so no difference in line thickness
NOTE: Only other change is my 3D page size to W170mm x H242mm
            When viewing in Creo Illustrator HLR i do not see line thickness difference either, not sure if you are supposed to.
Thanks for any help
Kind regards Gareth
Emeritus
Sep 11, 2026 4:38 AM UTC
Hi ​@GeeMac,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
