Aug 8, 2017 7:37 PM UTC
Pro/TOOLKIT: how to assign a texture with ProMdlVisibleTexturepropsSet()
Hi to everyone,
did anyone manage to assign a texture to a surface using Pro/TOOLKIT???
I managed to use the "new" (starting with Creo2 M140) Toolkit function ProMdlVisibleAppearancepropsGet() and ProMdlVisibleAppearancepropsSet() to assign a color to a comp/surface etc.
ProMdlVisibleTexturepropsSet() works as expected. But it seems that this isn't enough to display a texture on a surface. I think I must use ProMdlVisibleTextureplacementpropsSet() to define how the texture is placed/projected and so on. This function always returns -2 (INVALID INPUT)....
Before I paste some code here - WAS ANYONE HERE ABLE TO DO THIS?
Any tricks on how to define the ProSurfaceTexturePlacementProps object/pointer???
THANKS.
Andreas
Andreas
Aug 9, 2017 5:26 AM UTC
I hope that you asked PTC Support the same question 🙂
Aug 9, 2017 6:18 AM UTC
I have done that in pro develop in the past. But there are some stuff that didn't work at the moment, also inside the Coloring / Appearance section (remove color has some bugs). We have written Marc Fischer to that, but he is on vocation atm.
Br,
Eike
Aug 12, 2017 11:13 AM UTC
Thanks for the replies also when they do not help to solve the problem.
My problem here in Germany is that I have only one Creo license and one toolkit license. And I am no longer allowed to open a case for PTC's customer support although I am paying 1.000 Euro "maintainance" PER MONTH.................
I have to ask a reseller and that's usually a complete waste of time; I could also ask my neighbor's dog.
Andreas
FV_01
Aug 16, 2017 4:29 PM UTC
Hi all, Andreas, The first step is to verify that config.pro 'texture' option is 'yes'. The tricky part of the function is ProAsmitem - the usual initialization: ProAsmitem item; memset( &item, '\0', sizeof(item)); Setting the ProAsmitem, assuming that the part's ProMdl is mdl and it was initialized somehow (ProMdlCurrentGet or ProAsmcomppathMdlGet or ProMdlInit) ... ProMdlToModelitem( mdl, &item.item); item.name[0] = '\0';//redundant ProAsmcomppathInit( mdl, NULL, 0, &item.path); //for part or //ProSelectionAsmcomppathGet( sel, &item.path); //for a selected component in case of an assembly... The rest is straightforward - for testing - you should assign an existing texture to a model via UI, retrieve the texture with ProMdlVisibleTexturepropsGet(&item, &props); modify props.texture_map member with another bitmap - try to use one from the default library: strcpy( props.texture_map, "limestone-bump.jpg"); // for example and assign the modified texture to the model with : ProMdlVisibleTexturepropsSet(&item, &props); repaint window. HIH. Feliks.
Sep 25, 2018 5:23 AM UTC
hi all,
I get same problem in ProSurfaceTextureplacementpropsSet(),
the function always return PRO_TK_BAD_INPUTS.
I can use the ProSurfaceTexturepropsSet() set the surface texture image,
the part view also show the image,but actually the UI dialog ->color texture option is "off"
this problem make the part view blurred,
so i want to use the ProSurfaceTextureplacementpropsSet() improve the view,
but it's always return PRO_TK_BAD_INPUTS.
anyone know how to change the color texture option to image?
or
 know how to use ProSurfaceTextureplacementpropsSet()?
thanks!!!
