Display Geolocation Data Using Google Maps Part 2
- 0 replies
- 646 views
- Translate All
Step 5: Widget Properties
You can configure Properties to change the style of the map as well as specify a custom image to use for map markers. Other Properties allow two linear paths and polynomial regions to also be displayed on the map Widget with optional tooltip data.
Bindable
| Name | Type | Default | Direction | Description |
| Data | Infotable | None | Input | Source for the data that is displayed as discrete markers |
| LocationField | MenuName | None | Input | Field that contains Location type data to plot markers |
| MarkerField | MenuName | None | Input | Field that contains data of type Image used to plot markers |
| ShowMarkerTooltip | Boolean | True | Input | Hovering over map markers will display a tooltip when set to true |
| ToolTipField1 thru 4 | MenuName | None | Input | Optional field displayed in tooltip when the user hovers over a map marker |
| ToolTipLabel1 thru 4 | String | None | Input | Optional label for tooltip data |
| RouteData | Infotable | None | Input | Source for the data that is displayed as a connected route |
| RouteLocationField | MenuName | None | Input | Field that contains Location type data to plot connected route line |
| ShowRoute | Boolean | False | Input | Show route data on map when set to true |
| PlannedRouteData | Infotable | None | Input | Source for the data that is displayed as a second connected route |
| PlannedRouteLocationField | MenuName | None | Input | Field that contains Location type data to plot a second connected route line |
| ShowPlannedRoute | Boolean | False | Input | Show planned route data on map when set to true |
| RegionData | Infotable | None | Input | Source for the data that is displayed as a region |
| RegionLocationData | Infotable | None | Input | Region location data source |
| RegionLocationsField | MenuName | None | Input | Field which will provide location table information for region |
| RegionLayerField | MenuName | None | Input | Field that contains Numeric data used for region layer number |
| ShowRegions | Boolean | False | Input | Show region data on map when set to true |
| ShowRegionTooltips | Boolean | True | Input | Hovering over region will display a tooltip when set to true |
| RegionToolTipField1 thru 4 | MenuName | None | Input | Optional field displayed in tooltip when the user hovers over a region |
| RegionToolTipLael1 thru 4 | String | None | Input | Optional label for region tooltip data |
| RegionFillOpacity | Number | 1 | Input | Opacity of region fill color from 0 being transparent to 1 being opaque |
| SelectedLocation | Location | None | Input/Output | The currently selected location |
| CurrentZoom | Number | 8 | Output | The currently displayed zoom level ( 1 - 15 ) |
| Zoom | Number | 8 | Input | Number used to set the zoom level ( 1 - 15 ) |
| ShowMarkers | Boolean | True | Input | Shows map markers if set to true |
| ShowPathMarkers | Boolean | True | Input | Shows map markers if set to true |
| ShowTraffic | Boolean | False | Input | Shows traffic data color overlay on map if set to true |
| NEBoundary | Location | None | Output | The northeast boundary location |
| NWBoundary | Location | None | Output | The northwest boundary location |
| SEBoundary | Location | None | Output | The southeast boundary location |
| NWBoundary | Location | None | Output | The southwest boundary location |
| Visible | Boolean | True | Input | Widget is visible if set to true |
Static
| Name | Type | Default | Description |
| DisplayName | String | None | Name used for widget in user facing interactions |
| Description | String | None | Description used for widget in user facing interactions |
| MapType | Roads/Satellite/Hybrid/Terrain | Roads | The type of map content displayed |
| MapSkin | Normal/Blue/Grey | Normal | Options for styling maps monochromatically |
| AutoZoomBehavior | Data change/Initial Data only | Data Change | Controls when map will automatically zoom to show all markers |
| ClusterLocations | Boolean | False | Combines multiple location markers that are near one another into a single marker if true |
| MultiSelect | Boolean | False | Enable multiple marker selection |
Widget Events
- DoubleClicked- Triggered when user double clicks on the Google Map.
- Changed- Triggered when the data for this widget is modified.
- BoundsChanged- Triggered when the bounding box of the displayed map changes.
Step 6: Next Steps
If you have questions, issues, or need additional information, refer to:
| Resource | Link |
| Community | Developer Community Forum |
| Support | Google Map Widget Help Center |
| Free Google Maps Widget Extension | IQNOX |
