Sankalp Yadav
Application Error - faulting module ucrtbase.dll
  • July 25, 2026
  • 60 views
This error caused the kepware to restart automatically and the OPC connection to Ignition was faulted.
Best answer by ntripathi
Greetings ​@Sankalp Yadav,
I hope you are doing well.
Please take a look at the following article as it may help resolve your issue:
CS436358 - Server Runtime crashes with error in windows event log "Faulting module path: C:\\Windows\\System32\\ucrtbase.dll" in PTC Kepware Products
If you are prompted to log in to view the complete article, you can use your MyKepware login credentials.
ntripathi16-PearlAnswer
