How to write data into Kepware without using remote thing ?
Because of the problem https://community.ptc.com/t5/ThingWorx-Developers/ThingWorx-IndustrialGateway-cause-delay-of-the-data-tag-in/td-p/678674  I'm currently facing ,   I wonder  if  it's  possible to write and poll data tag of Kepware from ThingWorx without using remote thing ?
Sean
abjainAnswer
@seanccc : We need to have a remote template for things used for binding Kepware tags. As of now there is no other option.
@seanccc : I tried accessing the link . However it is throwing an error on opening. What is the issue you are facing on using remote things?
seanccc17-PeridotAuthor
abjain15-MoonstoneAnswer
Support
Hi @seanccc.
Since your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in the community!
--Sharon
