Is there a PTC recommended or easy way to connect 4 or more instances of Kepware in different sites?
I have 4 different sites, each one with Kepserver EX installed, is there a way or best practice to get connected all Kepserver each other? thank you
VladimirNAnswer
Similar discussion - "Is there a PTC recommended or easy way to connect two instances of Kepware?
Go to solution": https://community.ptc.com/t5/Kepware/Is-there-a-PTC-recommended-or-easy-way-to-connect-two-instances/td-p/647807
VladimirN24-Ruby IVAnswer
