KEPWARE MQTT SERVER
Good Morning,
I am using THINGWORX KEPWARE SERVER 6 for the first time. I need help please
I need to interact with a command box using the MQTT server on Kepware but I don't know how to configure or what is required to establish communication.
My goal is to be sure that I can communicate with other applications using the MQTT broker on KEPWARE.
THANKS.
VladimirNAnswer
Take a look:
VladimirN24-Ruby IVAnswer
Take a look:
Emeritus
Hello @LE_11058071,
It looks like you have a response from a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
