KEPWARE MQTT SERVER
  • May 6, 2024
  • 2 replies
  • 4586 views
Good Morning,
I am using THINGWORX KEPWARE SERVER 6 for the first time. I need help please
I need to interact with a command box using the MQTT server on Kepware but I don't know how to configure or what is required to establish communication.
My goal is to be sure that I can communicate with other applications using the MQTT broker on KEPWARE.
THANKS.
Best answer by VladimirN
Take a look:
VladimirN24-Ruby IIIAnswer
Take a look:
Community Moderator
May 10, 2024
Hello @LE_11058071,
It looks like you have a response from a community member. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
