Kepware REST Certificates, ThingWorx HTTPS Communication, and Java Truststore Behavior
Hi Experts,
I'm looking for guidance from Kepware, ThingWorx, and security experts regarding certificate handling between ThingWorx and Kepware, particularly around REST-based integrations and Java truststore behavior.
Background
Using Kepware IoT gateway I am downloading MES data.During troubleshooting of a Work Order (WO) download issue between ThingWorx and Kepware, observed that:
  • In one environment, WO downloads failed and the issue appeared to be related to an expired Kepware REST server certificate.
  • After addressing the certificate issue, WO downloads resumed successfully.
  • However, in other environments, the Kepware REST server certificates were also expired, yet ThingWorx-to-Kepware communication and WO downloads continued to function normally.
Initial investigation suggested that the difference may be related to the Java truststore (cacerts) contents on the ThingWorx servers. In some environments, the Kepware certificate appears to be trusted/imported into the JVM truststore, while in others it is not.
This has raised several questions about how certificates are actually being used in the integration architecture.
Areas Where We Need Clarification
1. Role of Kepware REST Certificates
  • What specific role does the Kepware REST server certificate play in ThingWorx ↔ Kepware communication?
  • Which functions depend on the REST endpoint certificate being trusted?
  • Why might an expired or untrusted certificate impact Work Order downloads while other communications continue to work?
  • Are IoT Gateway communications independent of the Kepware REST certificate?
2. Java Truststore (cacerts) Behavior
  • How does ThingWorx (JVM) perform certificate validation when making HTTPS calls to Kepware?
  • Under what circumstances can communication continue despite an endpoint certificate being expired?
  • What is the expected behavior when:
    • A certificate is expired but exists in the truststore?
    • A certificate is not present in the truststore?
    • A CA certificate is trusted versus a self-signed certificate?
3. Environment-to-Environment Differences
Assuming the following are identical:
  • ThingWorx application configuration
  • Kepware configuration
  • Tomcat SSL configuration
Could differences in the Java truststore alone explain different behaviors across sites?
Are there any additional configuration locations that should be reviewed (ThingWorx security settings, JVM options, Kepware settings, custom connectors, etc.)?
4. Recommended Long-Term Strategy
From a best-practice perspective, what is the recommended approach for production environments?
Specifically:
  • Should all Kepware REST certificates be renewed before expiry?
  • Is it recommended to move away from self-signed certificates and use CA-signed certificates?
  • Should organizations trust/import the issuing CA certificate rather than importing individual server certificates?
  • Are there documented PTC/Kepware recommendations for certificate lifecycle management across multiple sites?
Goal
We are trying to develop a clear understanding of:
  1. The relationship between:
    • Kepware REST certificates
    • IoT Gateway communications
    • ThingWorx HTTPS integrations
    • Java truststore validation
  2. Why seemingly identical environments can behave differently when certificates expire.
  3. The most robust and supportable long-term solution to prevent future communication issues related to certificate management.
Any architectural explanations, deployment experience, troubleshooting guidance, or references to official documentation would be greatly appreciated.
Thank you in advance for your insights.
MRohillaAnswer
Support
Greetings ​@TN_10343863 ,
Based on the observed behavior, the most likely explanation is that WO downloads use HTTPS/REST communication between ThingWorx and Kepware, which requires successful SSL certificate validation by the JVM. An expired, untrusted, or incomplete certificate chain can therefore cause WO downloads to fail.
However, IoT Gateway/Native Interface communications may use a different trust mechanism and can continue working even when REST-based operations fail, which explains why some Kepware-to-ThingWorx communications were unaffected.
Differences between environments can often be explained by:
  • Different Java truststore (cacerts) contents
  • Use of a custom truststore
  • Different JVM versions or SSL policies
  • Custom integrations that bypass certificate validation
  • Differences in the certificate chain presented by Kepware
Expected Java behavior is:
  • Expired certificate → SSL handshake failure
  • Untrusted certificate → PKIX/SSL handshake failure
  • Trusted CA-signed certificate chain → Successful connection
Recommended Long-Term Approach
  • Renew all Kepware certificates before expiry.
  • Prefer CA-signed certificates over self-signed certificates.
  • Trust the issuing Root/Intermediate CA rather than importing individual server certificates.
  • Standardize certificate, truststore, and JVM configurations across all sites.
To fully validate the root cause, compare the working and non-working environments for Java version, truststore contents, JVM SSL settings, and the certificate chain presented by the Kepware REST endpoint.
Mohit
MRohillaCommunity ManagerAnswer
Support
Mohit
