Unable to query recordset on Log Group 'Name' Reason: (Blank)
This was working yesterday, and during the night Windows installed updates and restarted the computer (this is on a development computer for now).
Not sure what the issue is. It connects to the DSN and says it is logging data. Then after that I get the recordset error, but no description of that the error may be.
cmoreheadAnswer
@LB_11012903 ,
The error message you are seeing is coming from the Operating System's DSN and indicates a problem between the DSN and the Table. Usually there is another user which has the table locked up. Please take a look at the knowledge base article in the following link
Article - CS323476 - Unable to Query Recordset on Log Group in PTC Kepware Products
If you are unable to locate the user that may have the table locked, I recommend opening support ticket with the Kepware team to perform more in-depth troubleshooting. Here is a link to the login page where a support ticket can be opened:
Log In | My Kepware
*Chris
It says it can't see that table in SQL (why no reason was given is interesting) - was the table or a tag it needs modified in any way? Did you update Kepware revisions? I danced with this kind of thing and it was from a tag change I made months earlier that Kepware was able to deal with while it kept running, but once I stopped and re-started it, it would no longer process that group.
In my experience it's always been something basic and simple that I never look for initially. so I always wind up smacking my forehead.
Sadly no. I have recreated tags, tables, and everything. Every time it stops, it happens. No-tag changes or table changes...
cmorehead13-AquamarineAnswer
@LB_11012903 ,
Log In | My Kepware
*Chris
