KenFarleyAnswer
Aug 18, 2022 4:13 PM UTC
I don't usually use pocket milling, but I'd imagine it behaves in a similar way to volume milling - Like a 2D bottom version, perhaps.
Anyway, I don't understand what you are expecting. If the pocket you are milling has sharp corners, when the toolpath is generated it will try as best it can to cut as much of the pocket as possible, given the diameter of the tool. It's not going to generate radii wherever the tool changes direction, if that's what you expect. If your pocket had large corner fillets, then the toolpaths would also have arcs in them, on the outermost passes of the spiral.
