Sep 23, 2016 11:32 AM UTC
Expert machinist
Hi all,
Simple question. What is expert machinist used for ? I've had a look at the help but it's not really explicit on what is the purpose of this module. Any idea ?
Sep 23, 2016 11:47 AM UTC
I was playing with Expert Machinist  last week. I was thinking that when I get swamped with the tough programming  I could get someone to help with simple programs. It's supposed to be in all Creo packages.  As far as I can see it's a very low end machining package that isn't supported very well with help files or tutorials on how to use it But it is functional for basic machining.
Steve
RaphMORIN16-PearlAuthor
Sep 26, 2016 3:51 PM UTC
Thanks Steve for this answer.
Sep 26, 2016 5:37 PM UTC
Expert machinist, also called NC Lite, is a 2,5D milling package that includes some drilling sequences. It is possible to run it even without Creo NC licence. The trouble is that the CL data are of no use without some sort of external postprocessor that you'd have to program by yourself.
Sep 26, 2016 5:50 PM UTC
James62,
I believe GPOST is available in all packages along with expert machinist as well as some post already created on the NC Central support page.
Steve
Sep 27, 2016 5:42 AM UTC
Steve,
with NC Lite Creo does not enable you to do postprocessing - GUI for postprocessing is not available. You have to run postprocessor outside of Creo - James62 mentioned this in his reply.
MH
