Jan 6, 2010 9:37 PM UTC
Imported Craptia model
I can't trim a mill volume to the Craptia file, can anyone help. E-mail me at david.dills@machspec.com
This is question for one of the programmers where I work that is learning about the user grop. Thanks all
Dave
Jan 6, 2010 9:44 PM UTC
"Crap"tia file huh? sounds kind a smelly.....
Jan 7, 2010 5:26 AM UTC
One thing you need to make sure that the model is a solid file. Even if it
imported as an igs, step or any other import you need to make sure that it
is a solid. Just because it shades does not mean it is a solid.
You may need to go in and and repair the geometry, and then you have the
option of making it solid.
Hope this helps
Tony
Jan 7, 2010 10:40 AM UTC
Hi Dave!
You might be experiencing accuracy problems. Try to set the config.pro option enable_absolute_accuracy to Yes and change the CATIA reference part, your MFG assembly and workpiece to absolute accuracy (0.005mm) - They all must have the same accuracy. Then try again.
If the above not work, try to do the same but also export the CATIA model with a smaller tolerance. (You have to set this in CATIA)
Some material about accuracy in Pro/NC
Jan 7, 2010 12:16 PM UTC
Dave
Whenever we come across a CATIA file we send it to CADFIX and tell them
we want a Pro-e model with .00001 absolute accuracy. We have paid
$200.00-$400.00 for the services but find it will worth it.
Mark Niles
336-996-6445
mniles@emeraldtoolandmold.com
