Mar 11, 2010 8:15 PM UTC
Pro man VS Mastercam
Version 7 is nothing like the newer versions of X2/X3. They are trying to make the interface look like pro/nc if you ask me. We have pondered the switch at times but Pro has so much more to offer in my opinion.
    Mar 11, 2010 8:40 PM UTC
    Worked with both and hated Pro at first glance... but today I won´t jump into MC because Pro offers much more being a true CAx app... you are going to see how handicapped MC is compared to Pro... a section to see and internal machining might be a pain in the ass... and the standalone verification sucks... you are better with CLPlayer and Vericut... BTW, by far better...
    Post-processors are easy to modify and enhance compared with FIL anguage, but it´s all about practice. FIL is more powerful and faster in my humble opinion, but MP Language is one of the best things about Mastercam post-processors. If the PPs are the biggest prize, then Mastercam might be a good choice... but for CAM... it is an awesome tool... however it´s not that good to justify the jump... the CAM i pretty good but you are going to miss the CAD capabilities of Pro...
    JM2C...
    Daniel Santos
    Suporte Aplicações CAM
    GE Oil & Gas
    T +55 11 4772-3565
    M +55 12 8173-6567
    F +55 11 4772-3775
    Rodovia de Acesso João de Góes, 2300
    Jandira - São Paulo - 06612-000 - Brasil
    Vetco Gray Óleo e Gás LTDA
    GE imagination at work
    The interface has change dramatically since 7, 8 9. Still easy to learn.
    The good thing about it is that you can learn as you go and be making parts
    the first day. If you can use Pro Man you should able to use MCAM.
    However, If you have a lot changes and large assemblies you might want stick
    with PTC. If you blend both packages, get the best both worlds. Expensive
    to do that. Especially if you need/use 4th and 5th axis. MasterCAM change
    the pricing beginning with X3. Full 5th axis now around $16,000.00
    Roger
    _____
    Mar 11, 2010 9:54 PM UTC
    The way I read this, it appears as if Terry is thinking of switching jobs, not dumping ProNC. He is implying that most of the places at which he will apply will probably be running MasterCam instead of Pro......so he will have no say in the software package.
    Mar 15, 2010 12:40 PM UTC
    I don't see the attraction of going to mastercam. If you have a pro/e part
    Pro/NC is much better as it is parametric. If mastercam is better I would
    be interested in finding out what features make it better. If I could see
    proof that it would be more productive I will listen. My guess is the
    learning curve would be the same for either if you had never touched a full
    cam package.
    Ron
    Mar 15, 2010 1:05 PM UTC
    Hi Ron,
    Even being a Pro/Nc fan boy I could not say it is that the learning curves of both packages are similar. Pro/NC is a totally different animal... and in some situations it is not intuitive at all... 6 years ago I learned MC as a self-taught... I don't think I could do it with Pro/NC...
    Pro/E has many advantages and cons compared to MC; the same is truth on MC side. I think that we cannot described in a post what would they be and keep unbiased at all. Too different beasts in my humble opinion...
    Jm2c,
    Daniel Santos
    GE Oil & Gas
    T +55 11 4772-3565
    M +55 12 8173-6567
    F +55 11 4772-3775
    Mar 15, 2010 2:16 PM UTC
    "I wish all my enemies would have to learn Pro/MFG'
    Me either. ROFL... 🙂
    Daniel Santos
    GE Oil & Gas
    T +55 11 4772-3565
    M +55 12 8173-6567
    F +55 11 4772-3775
