Mar 24, 2011 2:55 PM UTC
SIDE MILLING - hard steel
CONSTANT LOAD - tool path with small (.010) retracts.
Sep 19, 2011 8:04 PM UTC
Nick,
How do you keep the cutter from retracting? I am using constant load cutting and it works good but we loose some productivity because the cutter retracts between each step over. Any advice?
Sep 19, 2011 8:13 PM UTC
You can download that file and look at where my retract plane is set. You must be very carful about gouge checking this is more of a 50/50 solution it only works correctly half the time
Sep 20, 2011 6:32 PM UTC
You use this for facing the pocket? You cand use FACES ONLY I think. Or pocketing with STEP DEPTH > HEIGHT of the pocket.
Sep 21, 2011 5:15 PM UTC
Nick,
I have been using your roughing sequence since you posted it a while ago. It works great I think!! But like you say you really need to gouge check and watch the retracts.But it's a great time saver for roughing open pockets when you can start outside the work.
Sep 21, 2011 6:19 PM UTC
Nick, what's the HRC of your steel?
Sep 21, 2011 6:24 PM UTC
around 54-55 Rockwell. I will usually run 250-350 surface feet with .005" chip load per tooth usually at a full daim depth of cut.
