Oct 14, 2011 4:53 PM UTC
W5 Gouge Check Vs. Vericut
I've noticed that on some programs the gouge check done on a program in W5 shows gouges where Vericut doesn't. If I gouge check the sequnces I have no gouges. So my question is on what can I count on: Vericut or W5?
    Oct 17, 2011 1:10 PM UTC
    I count on vericut to show tool holder collisions and tool shank collisions. I use gouge check to find bad tool path (a all to common occurance) usually in roughing re roughing sequences.
    Oct 17, 2011 6:42 PM UTC
    I had a bad example today. I had 2 finishing and a surface mill sequence done with the same tool. When I made the output in a set it showed me gouges. When i did it separately it was ok. I think W5 is pretty bad at tying toolpath from different sequences, even if I use the same tool. Did you check the roughing - re -roughing problem with the amount of material left after re-roughing at 0 ? I used your strategy for helical mahining and I've noticed that sometimes it doesn't go all the way down to the bottom of the pocket. Have you encountered this by now?
    Oct 17, 2011 6:45 PM UTC
    I find strange issues everyday (2 this morning). I am getting very sick of Pro NC and would love to find a diffrent software pakage. any suggestions?
