3 unknowns but only 2 equations: Iterative approach?
  • June 27, 2011
  • 21 replies
  • 10960 views
The problem consists of 3 intervals (m) (they are called steps in the data below because the problem represents a physical glued joint with 3 steps (ie 3 different thicknesses) of length Lstep. The numerical problem I need to solve is finding constant A1 and A2 for each step (knowing a number of inputs). I was provided with the “raw” date for the solved problem and it seems that the constant A1 and A2 were found by an iterative process. For each step with length Lstep an initial (random?) value TR, at right hand end of a step together with the value at the left hand end (TL = T given at x=0) and does an Iterative process to calculate A1 and A2.
There are 3 unknowns but only 2 equations, Is there an easy (built-in!) iterative approach that can be used to find the value of TR, A1 and A2?
Regards
JXB
The problem is, as you stated, you have 3 unknowns and only two equations. I'm positive that there must be another relationship between the inputs which you haven't included.
Looking at it briefly, I don't think it can be solved with the imformation provided.
Mike
Mike Armstrong wrote:
The problem has 3 unknowns and only two equations.
See same task:
http://communities.ptc.com/message/158454
23-Emerald I
June 27, 2011
Your solve block yields results, but they are not the same as the expected results.
Mike
23-Emerald I
June 27, 2011
Mike
Actually it does if you get the equations in the solve block written correctly!
I must use one unknown but 2 equations by solving this task
http://communities.ptc.com/videos/2045
Why!?
See here http://communities.ptc.com/message/164665 this two equations in the Given-Find block!
