3 Variables Cubic Polynomial
  • November 5, 2010
  • 10 replies
  • 4787 views
HELLO,
Please help me to construct a cubic polynomial with 3 variables.
I am trying to make a cubic polynomial from the function Zf with 3 variables, namely Rho, Alpha andX0
I have attached the worksheet (MathCad 14), so, any help would be greatly appreciated.
Thank you,
Anousheh
Why have you created a second thread?
Is this not the same problem as the first?
Mike
Anousheh1-VisitorAuthor
Hello Mike,
This is the same problem. I had problem creating 3D graph. This is now solved.
I need to write the actual cubic polynomial using the function Zf. No one answered me before, that's why there is another thread.
I need help on this.
Thank you so much
Anousheh
Just because someone hasn't replied doesn't mean you won't get a solution.
I have saved your Mathcad worksheet down to M11 format for a wider audience.
Mike
