23-Emerald I
January 9, 2012
Each time the Adapt(f,a,b) function does not return an answer within tolerance it subdivides the interval and applies itself to each half.  This process continues (reoccurs) until the desired criteria are met.  So a process mght look like:
        fail
                              fail        fail
          fail                              pass                              fail                              fail
pass               pass                                             fail               pass          pass     pass
        pass     pass
The answer would come back as the sum of the passes.
Joeboy1-VisitorAuthor
Thank you for the help Fred.  How does the program exit the loop ? Is there a maximum number of passes it can make ?
23-Emerald I
January 9, 2012
The idea of recursion is that the program will call itself over and over, as many times as it needs to.  So each time the test of criteria are not met two more instances of the program are launched.
When the criteria are met, the answer (correct to the specified accuracy) is retruned. In the small example above, fifteen different cases of Adapt were launched.
Fred, I don't see the small example you refer to
23-Emerald I
January 9, 2012
The first comment:
        fail
                              fail        fail
          fail                              pass                              fail                              fail
        pass     pass
(Might make this a discussion rather than a document--it's easier to see revisions/ comments.)
