Additional Dimensions for Mathcad Prime 3.0
  • October 22, 2012
  • 6 replies
  • 4250 views
I would like to see in Mathcad Prime 3.0 not only Additional Units - see http://communities.ptc.com/message/190702
but also Additional Dimensions (Physical quantities😞
  • concentration
mg/L, mol/L, mol/kg, p.p.m., p.p.b. etc
  • specific heat capacity and entropy
kJ/(kg K), Btu/(lb °R) etc
  • enthalpy
kJ/kg, Btu/lb etc
  • quantity of information
bit, bite, kB, MB, GB etc
etc
What would you like have more?
Mathcad Help file refers to dimensions as base units, so that is what I assume you mean by dimensions.
The current (Mathcad 15) base units are as follows: current, length, luminous intensity, mass, money, substance, temperature, and time.
All of your suggestions except bit, byte, etc can be expressed in the base units. I see no need to start having base units that are in fact combinations of true base units.
Now I must use in my steam-gas thermal cycle calculation two Physical quantities - mass of water/steam and mass of gas:
|-User units-------
kJ/kg:=1000J/kg kJ/kg:=1000J/cd
|-User units-------
See for example Fig. 2.19 here http://twt.mpei.ac.ru/ochkov/T-2012/Chapter2-Units.pdf
I have a dream to have 3-7 user dimensions (Physical quantities) in Mathcad - mass of water/steam and mass of gas for example.
One more simple example - Function of the cylinder volume.
We have TWO Physical quantities(dimensions) - length-diameter and length-high (of the cylinder).
No error message but must be an error:
An Error message:
http://twt.mpei.ac.ru/ochkov/Mathcad_14/Chapter2rus/2-16-cylinder-m-d-m-h.PNG
