An Arrow above a function?
  • November 25, 2010
  • 6 replies
  • 7369 views
This may appear to be a stupid question but I saw this in the built in help and did not know how to enter it into my file.
This arrow above the function. How do I enter it?
and above all why is it there? What does it do?
Thank you
Best answer by MikeArmstrong
In the minerr quicksheet example x and y are a vector of values. So the function has been vectorized so each value of x and y are passed to the function inturn.
Mike
Its called the Vectorize operator and can be founf on the Matrix tooler
Description from the help menu:-The vectorized product returns an array of the same size as A and B in which each element contains the product of the paired elements of A and B. The non-vectorized product performs a standard matrix multiplication.
Simple example below.
This is a very useful function and is constantly used by forum members.
Mike
UKMan1-VisitorAuthor
Thank you for the helpful reply. I now understand the concept of the vectorize operator and it is easy to see it from your example but why use it in the screenshot I provided?
its not vector multiplication? So why is the vectorize operator used there? and what would happen without it?
BTW the screenshot is from the minerr quicksheet
Its doesn't have to be used on a vector mulitiplication, look below.
The above retuens an array. 1 if the element in row is not zero, a zero is returned otherwise.
Mike
