Best answer by AlanStevens
Do you mean like in the attached?
Alan
Why are you solving it symbolically in the first place then?
Mike
EricHong1-VisitorAuthor
There will much more stuffs after this. If I can somehow assign elements of the symbolic solution in the file to variables, I can use vectors as inputs to them and things will be much easier for me.
If I can do the following:
Variable := Find(Pc1_ret, Pc2_ret, A22, A44, Q22, Q44)
Pc1_ret(Ape,Apr) = Variable[0
Pc2_ret(Ape,Apr) = Variable[2
Then, I can use vectors containing min/max tolerances (as shown in the file, +/-10%). Do them to all parameters and other set of equations and at the end I'll have a flow rate tolerance band.
Of course, I can make three more copies of the same file and perform this analysis separately, but how lame!
I hope my explanation makes sense.
Eric
Alan
