Assign greek letters to variables
  • November 21, 2011
  • 4 replies
  • 2872 views
Hello.
Is there any way to assign greek letters to variables....
For instance if I say A:=1, MathCad will assign the variable.
However when I try doing A:=alpha (using the greek symbols panel) it doesn;t work. When I type A= it tries to get me to assign the variable, and wont return the value of A to me.
I'm using mathcad 15.
Cheers
Message was edited by: Adam Yip
May be so:
If you type
A:=1
A:=alpha
Then if alpha is undefined, so is A (and the second assignment will show an error). That's why if you try evaluating A you get an assignment operator.
What did you expect it to return? The value 1?
Send please your sheet!
Hello!
Maybe this will help:
P.S. What is the original formulation of the problem and what you want to get in a result?
Please provide a worksheet.
Mike
