Building Structural Design - Wide Flange Columns
Chapter 5: Structural Steel Columns - ASD Design, Part 1
Description:
          This application allows the user to rapidly check trial sections and to determine that the standards of the AISC Specification, Eqs. (H1-1) and (H1-2), are met. For input, the user only needs to enter the flange width, the section depth and the section weight. The necessary section properties and parameters are then computed by this application.
Next: Chapter 5, Part 2Previous: Chapter 4, Part 3
