Calculating a Scalar in a Matrix
  • May 18, 2011
  • 16 replies
  • 8425 views
I have a matrix, where each column in the matrix represents a different calculation. I need to create a new column in the matrix where I sum the values in the first column and compare it to each individual value in the second column. I'm having trouble programming this in a for loop because Mathcad keeps telling me the value must be a matrix of scalar elements. I've attached an example worksheet. Let me know if you have any questions.
thanks!!
23-Emerald I
May 18, 2011
You're not doing a summation.
I don't understand the double loop!
Fred
Anne
You are summing an element ( TEST[k,1) , change to summing the column ( TEST<1> )
23-Emerald I
May 18, 2011
Wayne Reid wrote:
Anne
Since Anne is developing the first column row by row as she iterates through the matrix the sum of the lolumn will change each time through. Need to be careful!
Hi Fred,
I know, I think that might be what she wants though, can't really tell as her example is just a test and not the real thing?
It's not clear to me what you want (or, judging from the other replies, to Fred or Wayne either). The text of your post implies that you have an existing matrix, and want to subserviently sum column 1, and compare the sum to column 2, so the sum does not change for each comparison. But your worksheet implies that you are creating the matrix at the same time that you are doing the sum and comparison, in which case the sum is different for each comparison. Which is correct?
amaurer1-VisitorAuthor
Richard,
I want to compare the additive total of Column 1 to each element in Column 2. Therefore, the sum should not change, only the "flag" (i.e. either 1 or 0). I'm trying to build a "failure" flag into my programming loop in order to determine when the individual values in Column 2 exceed the total of Column 1. I hope this clarifies the question.
If the sum is constant then the matrix must exist before the program (or at least before the part of the program that does the sum and comparison). So will this work?
