Calculation problem in MathCad Prime 2.0
  • July 22, 2012
  • 8 replies
  • 3118 views
I'm having a problem getting a correct answer in MathCad Prime 2.0. I'm running a simple algerbra formula in which the answer should be 3.31, but MathCad keeps giving me 0.00. Is there some setting to force the program to give me the correct answer? Thanks.
Best answer by AlanStevens
The calculation is correct! You must have used the wrong variables - see attached
Alan
Post the worksheet with the problem.
Alan
I don't know how to upload the worksheet.
Look at top right hand section of reply editor and select Use advanced editor. Then you can upload a worksheet using the facility at the bottom of the advanced editor.
Alan
